Front fog light relay wiring.
Just a quick question about the wiring on the front fogs. I have searched the forums and checked in the wiring diagrams but couldn't find what I needed. Basically my front fogs wouldn't work took it all apart relay was knackered but someone has also cut the black wire going to/coming from the relay? This looks like they've replaced it with their own earth on the relay connection block but left the other wire disconnected. When you touch the disconnected black wire to the earth that looks to be put in after the lights work but when the earth is removed and the black wire put in place the lights won't work. My other 5 doesn't have the extra earth cable on the relay so was just wondering what one is correct or if both are? I've left it disconnected for now. Thanks
