Info please :)
B18FT
1 bar of boost
249cc injectors
Standard throttle body
T2 blower.
FSE adjustable fuel reg.
This is what i got. ( Lap on Mallory last year)
Cold idle 10.1 AFR
Hot idle 11.2 AFR
On boost at 1 bar 15.0 AFR !!! ( Reading using standard fuel regulator)
Now it maybe lack of fuel pressure on boost causing crap AFR on boost.
What setup would people recommend?? 32mm bypass?? Does the maf pot adjust fueling at idle only??
Just after a good proven setup then i can fine tune it on the dyno.
Cheers
Nick.
