Re: Fly wheel for EFI - C1J
Hi Andy
Good digging :cool:
The bolt pattern - one bolt hole is offset slightly on the C1J, so does the scenic one maybe not have the offset, or maybe its offset the other way ?
Scoff
Hi Andy
Good digging :cool:
That got me thinking - I assumed that the holes would all be evenly spaced, so when comparing 1 against the other I had the back faces of each touching. As it happens, if you turn them around they all line up.:D
Which only leaves the clutch recess I need to get me a clutch plate from somewhere. I'll ask around the local massive.
Andy
very good gen andy,is the pic up for the tdc sensor in the same place on the g/box?
TNT ANDY
Andy
i has millions andy! got about 2-3 used clutches u can have to play with
markey b
Nice one TNT Markey. I'll pop down next week if I can. BTW, the TNT stands for you blow stuff up a lot. ;)
michael tierney
Yes it's in the same place. But I don't know what sensor you would use. I. Would like to think you could use the standard 5 pick up.
That's great news, once the clutch is checked we need to try the 215mm next..... I wonder how different that 1.6 crank is to the c1j
Chris
TNT ANDY
i like to keep myself busy, and i also love to take my engine apart and replace expensive core components.......:laugh:
always worth it though :cartman:
Doesn't the 200mm Volvo 440/80 flywheel not fit, pretty sure it works with Efi as well ?
Although I expect the scenic one would be more readily available if it will fit..
5teve L
No, the bolt pattern is different to the c1j
Miller
Ah, I'm getting confused now with the F7P :homer:
