I know this is prob the wrong place but it is the best place to get part numbers i am in need of the clio cup alternator bracket and the belt and a picture of the dialogy screen.
Many thanks
Many thanks
your in the right place, but I'm not...
back at work tomorrow....
i take it the above is a clio CUP....the type without Air-con...?????
http://i88.photobucket.com/albums/k1...megane/172.png
its unclear from this pic......but looks like its attached to number 1...
7700868118....£70.00 ish quid....
GOod crack might change my setup to this one :) Looks a bit more robust!
if you can get one 2nd hand could I borrow it and I'll get a load laser cut for nixy?!
this is the early type ren 19,21,trafic,clio etc.......
http://i88.photobucket.com/albums/k1...1170M065_1.png
the long metal one, 7700718613 £20.00+VAT
Paul your a star thats even better.
Cheers James
i de aircond mine on the cheap, scrap yard bits, i now run the setup off a volvo 440, 1.7. totaly fine, needed to get a pipe made up for it as the volvo pas pipes didnt line up with the clio ones, no hardship tho. well worth it as the cup alternator and bracket setup is quite exspensive
