Re: Braided oil cooler pipes
There is a company that does them, Hose Solutions if I remember rightly.
Have a look in the contacts section area place :agree:
Plus we get a hefty discount :D
Spooky
Cool mate cheers, il have a browse!
Is your oil pressure gauge working?
If you care about you turbo / engine lasting you should make sure the internal diameter of the fittings for those braided hoses are as wide as the OE.
The over braided hoses I bought and immediately returned had a very very small hole through the fitting and I didn't want to take the chance.
Low oil pressure is a main cause of turbo failure.
Been thinking about solutions to this & the gt tuning intercooler originally came with two adaptor fittings that go into the rad to move the oil cooler hoses away from the intercooler a couple of inches, might be worth sniffing some of them out:)
oh on my vfm look up at work says its a normal r 5 80 bhp lol:laugh:
what oil pressure does everyone have, i get 20psi after the car is warm and 60 wen i have just turned her over.
Are both those readings taken at idle ?
yes forgot to mention that and then once warm and i start driving it goes up to like 40 - 45 if i remember from the 20 idle, just wanted to see if thats the norm.
Ian S
It's on and off mate.. Il probs buy a seperate oil pressure gage
Brigsy
Think a shud hoy it in the wanted section? Or should a gets seperate oil cooler?
See if you can get the adaptors first mate, cheaper than any other option.
benj88
It's on and off mate.. I'll prob buy a separate oil pressure gauge
You should plumb it in to the oil inlet just above the turbo.
Not sure if these might help ya? No idea what diameter they are inside?
http://cgi.ebay.co.uk/Renault-5-GT-T...item51909375d3
UnstableCable
I noticed these the other week and wonderd if they would be any use..? Anyone think there useable?
They are the hose solution set, he also trades as hel.
Best to go direct and get the club discount
Get an oil pressure gauge first.
The ones I had were 2nd hand and had kinked near the bottom fitting as the fitting was too long and stuck out too far forcing the hose back against some engine part, I forget what now, but maybe the turbo oil drain metal pipe.
I felt it was occluding the bore a bit. But that was nothing compared to the occlusion of the tiny hole through the fittings.
benj88
I noticed these the other week and wondered if they would be any use..? Anyone think there usable?
The only way is to buy a set and compare the ID of the fittings with the OE.
If they are still a lot smaller then fit a decent oil pressure gauge first, note what your pressures are for cold and hot at low and high RPM, then fit the over braided hoses and see if your pressure has dropped at any point.
ben if your thinking of a aftermarket oil pressure gauge ive got an oil temp, oil preesure and boost all brand new on ebay now, ad give you all 3 for £55
http://cgi.ebay.co.uk/ws/eBayISAPI.d...STRK:MESELX:IT
Are those actually 'decent' gauges?
I agree they are cool and groovy with their appearance.
A pal had some similar a few years back but didn't seem to get them to actually measure anything.
As far as oil pressure goes, it's the rapid end of your turbo and engine that's at stake. That's not somewhere you want to sacrifice reliable accuracy for prettiness.
If they do the job well then that's great as it's an electric oil pressure gauge and it will be much easier to take wires to it than to take a small stiff over braided Teflon hose filled with high pressure engine oil.
there supposed to good yeah mate , only reason im not using them is my R5 has a gauge in the dash and i dont wanna change dash and i dont want to have odd gauges, alot of subaru owners etc use these gauges.. there unused brand new
I have fitted the braided oilcooler hoses to bens gtt. Has anybody got any pics of them fitted to compare?
Crap fit imo, although they do fit better than the originals with the breadbin cooler. No kinks just poor piperun. Also the olives that fit over the metal pipe are crap in my opinion, they have nipped up though so until i get it fired up i wont know if they leak or not..
