you get a coil over kit to lower your car . you lower it say ,
50mm ,comes the mot time the car gets jacked up
and obviously without the weight of the car on the system
piston rod lifts up leaving the coil loose .
seeing this the mot man says "coil springs not correctly located"
now i understand this may cause trouble with standard type suspension
but with coil overs the coil cant really go anywhere .
so i ask you , are coilover systems really dangerous/illegal
or are the mot testers missing the point :confused:
