Get in there :-D, lovin the Gordini
Today is a good day... so far.
I got my "secret" car about 3 weeks ago now, its been on my drive under cover not been used....
About a week ago Dale Jarvis came down and brought a new battery with him, chucked it in the car, tried to start it but no fuel was reaching the engine :-( So we left it alone and decided to work on it another day...
The car has an Alloy swirl pot in the back with 2 fuel pump's, I suspected the fuel pumps were to blame, So today I checked all the fuel pumps, wiring & plumbing...
Put the key in, and joy of all joy's it started first time :)
Let the engine tick over, kept an eye on the oil pressure & water temp, all was fine, made sure all the lights work and decided to give it a wee drive around my estate (on private road ofcourse), it goes very well.
Now I have to fix a few minor lighting issue's... most likely bulps or connectors need cleaning, & then book in for an MOT this week. :D:D:D
Re: Get in there :-D, lovin the Gordini
Thought I booked the MOT for today, but its for tomorrow... wish me luck
well nice car , very clean happy days:)
I'll admit, the Gordini turbo's are uber cool. Eug used to leave me drive his old one around every now and then, proper retro. He always wanted to do the gt turbo carb conversion to it but someone ran off with his money for the parts so he left the car for waste after taking it apart.
Penfold
Well it failed, after 2:30 hours at renault, I was presented with 2 pages of failure's.....
Nothing major, just a day of work on the car and will be fine, & luckily nothing going to cost as no parts need replacing.
01) Windscreen washer provides insuffucent washer liquid
02) Nearside Headlamp aim to high
03) Offisde headlamp aim to high
04) Offside Front Front postistion lamp(s) adversley affected by operation of another lamp
05) Offisde front direction indactor not in good working order (not working)
06) Nearside (stays on with side lights) direction indicator adversely affected by the operation of another lamp
07) Nearside (outer) Front Constant velocity joint gaiter split
08) Nearside (seat no bolted down correctly) Front passenger seat insecure
09) (body work seat bolted to cracked) Drivers seat insecure
10) Nearside Rear Passenger seat cannot be secured in upright postion
11) Offisde Rear Passenger seat cannot be secured in upright postion
12) Offisde Rear Parking Brake recording little or no effort
13) Parking brake efficiency below requirements (15% recorded)
Advisory Items
14) Windscreen has damage to an area less than 10mm circle within Zone A
15) Windscreen has damage to an area less than 40mm circle within Zone A
16) Offside front vehicle structure has slight corrosion
17) Battery Insecure
18) Offisde Front fog lamp not working
19) Offside Rear shock absorber touching on rear suspension arm
20) Nearside Rear shock absorber touching on rear suspension arm
Adam L
you mean the one i bought and broke? - the roof is currently sat on a white turbo 2...
Clee, you could buy Phil's white gordini.....
Sparkie
If someone bought the 21 .....but it's only got two doors so not to good as a sprog mover ...
