safety pressure switch..the connector with 2 wires in the boost hose to intercooler. got new hose set. theres no hole or anything. do I really need this? no perc set up will be used if any help..
No you dont need this, it wont fit in the new hose and take it you'll run more than stock boost anyway ;)
yep.. thanks mate. no need to butcher it up..
FYI if i remember correctly this is the over boost safety switch, you can adjust the screw on top of it to compensate for a higher cut off threshold if you are running higher boost. It cuts the ignition if you hit the boost limit set on it.
But as others have said, just ditch it. Thats what most people do.
