Re: Head gasket change????
The most complicated part..... ie not bolting something on off is the tappets adjustment once its back together. Also make sure your headbolt holes are blasted out(not full of water/oil) bolts dont like to compress oil/water and if they do they head wont torque down properely.
Other than that its a pretty easy job unlike an ohc engine.
Good luck you'll be fine.
Keep both surfaces very clean, new bolts, torque down to 75 nm if installing updated bolts. Also check for warping on the head. If memory serves me well, anything more than 0.05 of an inch may need a skim. Follow the good book and you'll be fine.
If you get to a part that you get stuck on, leave it and ask the question, don't panic, take your time.
another basic tip is when u have al lthe head bolts out dont lift the head straight off twist it then lift other wise may disturb a liner
ooo
oo
Another great one.
Cut the tops off 2 of the old head bolts and cut slots in them.
When re-fitting the new head, have these 2 in the 2 front outer most holes and use these to guide the head on. This will allow you to drop the head down and avoid it slipping off when you go for the bolts. Put the rest of the head bolts in finger tight, then remove these 2 studs and put the final 2 head bolts in.
Torque down to 40nm, then 60nm, then 75nm.
:agree::agree::agree:
TNT ANDY
ooo
oo
Another great one.
Good tip :agree:
TNT ANDY
ooo
oo
Another great one.
I do this too. ;)
But I'm pretty sure when I tried with the dizzy still in place it would catch on it.
