hi guys does anyone know were the return value is because when i pump my pedal my revs go up i trying at the servo but could nt find it
its on the back of the manifold there are two of them
there is two pipes but no return valve wot that about?help
so its not part of the pipe then ?
correct, not part of the pipe.
you need a 21mm or 22mm spanner to undo the valve once you've taken the pipe off. you can check the valve by blowing through it both ways, obviously you should only be able to blow "into" the manifold, not out of the manifold :)
i have i look 2morrow and let u know thanx m8
it's normal for thr rpm to fluctuate when you pmp the brake pedal at idle
but it goes from 1000 rpm to 1500 plus rpm that can be rite just by pumping the pedal?
no , it isn't . if your tick over was 1000 rpm it would rise to about 1150 - 1200 rpm . but no more than that . some cars don't go that high . :agree:
yeh so im going to check return values then look for air leaks after i done my heads gasket:o
