I ve been searching and i need to know the exact spark plugs to buy... i have to get them online as i cant get to a halfords.
for example follow link see options
http://www.halfords.com/webapp/wcs/s...C%7Cpag%7C%7C1
WHICH ONES?
WHICH ONES?
NGK B8 EVX is what most people use mate :)
cheers chris but whilst searching ive come across alot of views about standard campus plugs working just as well. does anybody know the code for these? as in champion . . . . whats the specifics?
Also cant find anything usefull on home delivery/buy online at halfords maybe im just dumb.
Have a sniff around this site dude http://www.sparkplugs.co.uk/ as thats how I found all the schpiel below...
Results and information
Manufacture RENAULTModel 5Engine Size 1.4 L No. of Valves/Cylinders 8V / 4CylVariant GT (Turbo)Year of Manufacture 1980 -> 1992Power output Not Specified BHPStandard gap setting 0.8mm
Part Number N3GShort Code (aka) OE078
Price (£) Per Plug 6.07+vat
Ahh bollox, you get the drift :sad:...:laugh:
n3g, n3c, or n2g, n2c if you want to go one colder. halfords and the like tend not to stock them though.
have u tried using an ngk bc8 es
its a standard escort turbo plug, there cheap reliable an work great
proven on many things around my way
even the time atack sky line i was out in at snet on thursday
ordered mine direct from renault
there the 1s dale
cheap as chips and last and last
Yep, £5.11 for the set I get mine for :) very cheap
would these work on the gt turbo then... where do i get them from ? that cheap of course:)
hell yeah.
:)I use NGK B8-EG. Fine for me, never had a problem with them. They are the same spec as many of the supposed 'tuners' used to supply for 'high boost applications'.
Cheap enough...
http://cgi.ebay.com/NGK-spark-plug-B...3286.m63.l1177
I use ngk B8EVX, have done for years with no problems. The std gtt plugs (champion?) were ok last time i tried a set.
Wont get them as cheap as £5.11 but try any factors. For my company we can charge them out at £1.50 + vat each. Did offer these plus many other service parts to the club as could build up service kits to then people to purchase but nothing came about of it :(
B8EVX plugs are not the cheapest of plugs, £13.52 for me from work.
Thats the list I gave them, this was back in March this year though so things might have changed by then. But I did offer to sort this out then drop them off when we meet at national day. Obviously this too late now though. But im thinking that also how many people are going to get all these when you might not save that much or can get cheaper elsewhere.
B8EVX spark Plugs - £3.85 each
Distributor Cap - £6.18
Rotor Arm - £1.54
Air Filter - £5.48
Oil Filter - £5.06
Fuel Filter - £5.82
Drive Belt - £4.17
Timing Chain Kit - £13.91
Exhaust rubber mounts - £0.56 each
Valeo Clutch (should be able to get hold) - £84.11 - Will get cheaper possibly
Front Brake Discs - £22.52 pair
Rear Brake Discs - £38.14 pair
Front Wheel Bearing Kit - £19.22 each
Rear Wheel Bearing Kit - £32.75 each
Front Pads - £12.53
Rear Pads - £10.74
Rear Pad fitting Kit - £7.93
Water Pump - £66.11
Rad Fan Switch - £10.93
Thermostat - £7.23
Phase 1 Fuel Pump (uprated) £66.11
18" Wiper Blade - £2.24
18" Spoiler Wiper Blade - £3.22
Rear wiper Blade - £2.18
Headlight - 472 Bulb £1.24
Rear Lights - 382 - £0.21 380 - £0.25
All prices are + vat @ 15%
Most of those I should be able to take 10-20% off pricing depending on which ones and how many you want to buy
Front Shocks?? :D
Just had a look as well, front headlights, not available from valeo anymore :( but can get for around £20 + vat depending on numbers each.
