http://wap.ebay.co.uk/Pages/ViewItem...cooler&emvcc=0
Shouldn't be too large should it ?
Nope thats the one phill is using and seems to fit nicley, I didnt see that one and got the bigger one, still fits just requires cutting of he cross member. But that one will easily be big enough.
Shall get one on order now then.
I take it your on about the medium twin pass the same seller does ?
Yep which is a bit overkill tbh. That one will be a lot simpler to fit and easily up to the job.
Cheers for the help mate.
Just got to figure out how to pipe it in. Rooms a little right with an f7p in the bay
I got one of those pipe kits off the bay with lots of pipes n connectors. Did the job for the b18ft conversion
I might invest in one of these then, so will this fit with no cutting required dont spose you have a link for the pipe kit.
Thanks Mat
Think thete is a little cutting required but very minimal if phill did it to his baby:cooter: type intercooler pipe kit into the bay and have a look at em as ull have a better idea than me as to which bunds ul need.
