setting up throttle position sensor?
right i have taken my b18ft and b18ep throttle bodies apart, i have used the body and butterfly from the b18ep (as the venturi is larger) and used the shaft and springs etc... (had to file the shaft out to take the larger butterfly) from the b18ft. Now the throttle position sensor sits where you want it to, but there is adjustment on it. To get the sensor set in the right place do i just twist it as far as poss with the throttle closed or is there a proper procedure??:confused:
Re: setting up throttle position sensor?
depends if your on std injectors or not. you'll notice there's a 'click' for idle position on the map, so it should click as it opens and again when it shuts. if using larger injectors you want to set closed position just past the click, as the ecu ignores afm during click and just runs off a set point on the map, thus overfuelling with larger injectors
cheers haz im using standard injectors so il set it just past the click like you say.
