Re: Fuel pump pressure f7p
Infact I only get the power light on my ecu?
think i forgot to mention it a adapronic ecu :ashamed:
If it's adaptronic then the fuel pump signal is only set to 10sec's I think the max you can have it on prime is 30secs.
Once the car is running it will run constantly.
before the engine died, when u put the ignition on the fuel pump would fire up and sit a 3 bar but now its doing nothing, injectors wont work, have not even checked for a spark. it did start, turned it off went to restart and nothing :( its gott be the ecu. i waant to bring it to pod :(
Found the main problem ! The crankshaft sensor had somehow rubbed on the flywheel and broke/cracked the sensor :confused: but i had a old spare :)
It starts now! Just need to fix the fuel pump bit as i wired it straight into the mains to get it to run.
