Re: like driving a tank!!
good air pressure in tyres all ways helps.
is there anything on the rack that can go stiff?as one of the gaitors wasnt covering the teeth on the rack noticed it when was fitting the starter today
my r5 went really stiff when it was off the road..
now ive drove it its fine :) ..
U/J.....?
Hang on....ignore me...I'm thinking Clio again.....:(
Tyre pressure, allways a good idea to fill rack gaiters with lubricant and work the rack lock to lock. makes the rack feel super smooth if its gone dry :D you made any suspension mods or wheel changes?
I think on some racks there is a little bung in the casing, you can pop some lube in there....EP90 (rear axle oil) works well......
Also worth checking the suspension top mount bearings, they can make the steering stiff.
thanks alot will check, i have 15 inch alloys on with yokohamas and have avo adjustable coilovers. how can you check top mounts?
