Gearbox issues
Well bin a good week managed to get new crank seal in, engine back in all up and runnin drives and pulls very well, only issue is to reverse i have to hold it in gear and it still kicks it out somtimes, 5th also feels the same its the r5 box on b18 lump anyone any ideas, thanks
Re: Gearbox issues
could you have bent or moved the linkage? could just be a faulty box, if its a fault from before you stripped it and gettin worse then more than likely
Re: Gearbox issues
when it was on c1j it was fine, could av bent somthin without realisin i suppose, i also fitted quick shift and shorter link so may fit standard link to see if it alters anythin, thanks for that anyway
Re: Gearbox issues
well had another play with this little prob today, put the standard link onto box gave it a try and bang on, first gear a little tight but thats bought it , one step closer for mot :)
Re: Gearbox issues
if its a lil tight then just adjust it more. i've used the b&m short shift and after alot of reducing the ball on the end of the small linkage rod, ended up puttin the original back on wth the short shift lever.
