right, i know the fitment and may have found some new alloys as mike buckled one, im waiting on a email about the centre hole but ive just noticed there 6.5j thou will the 195/45/15 toyos fit ok thanx mick:agree:
Centre bore for renault is 60.1mm, although can use spigot rings to ensure correct fitment. Need to be 4 x 100 PCD which is for the holes for the bolts. Any ideas on offset? can run spacers if needed :)
Ah ok, so .5j is the difference in width of the rim itself, 5mm? :scratch:
The width is the section between the tyre mounting flanges on the wheel
http://www.rimstyle.com/pages/alloy_...explained.html
thanx sir what i mean is on the current 7j rims the tyre sit flush with the rim with 195's because these are slighty smaller i was wondering if the 195's would bulge slighty
does anyone have a 195/45 on a 6.5j rim to tell me ot have a pic??
thanx mick
195's will be fine on 6.5j :)
ok what about 16"s on 195/45/16 with car lowered 35mm, has anyone done this??
do they rub??
thanx mick
mick it will be fine audreys car runs 195/45r16 now and it used to run 205/40r17 but the tyres where to hard for the 5 suspension setup.
