Ok stripping down a block due to oil & water mixing somewhere came across a likely reason why but on the way i noticed on the valves a crack in between them all bar one pair....
what you think oversize valves causing a weakness in the head?
also on the bottom block you will see a 3 way crack going into the waterways now do you think the water could track up the headbolt into the rockercover?
http://i728.photobucket.com/albums/w.../Photo0528.jpg
http://i728.photobucket.com/albums/w.../Photo0527.jpg
