just put one of these on my 5 seemed ok when i set out for abit now it seems like its misfiring pop bang like the over boost is connected hesitating spluttering the lot ???
:confused:
:confused:
Its probably coincidence that something else has broke, exhaust wont make any difference
Maybe just easier to hear now with the sidey. As brigsy says exhaust won't do anything
thats what i was thinking seems like fuel issue ? maybe spark ? any ideas what it could be and what to check ?
Just a thought but it isnt blowing the spark out is it
What boost pressure are you showing now and is it significantly more
Than before you fitted the sidey?
With a much less restrictive exhaust turbos tend to work better
But I'm with brigsy on this one something else has probly broke
not sure about blowing the spark out ?
its still running same boost 10 psi
ive still got stock turbo elbow
seems like when you put foot down it just dies now and then and backfires
I had this many moons ago when I changed to a sidey, I ended up taking it off and putting my scorpion back on. However, back then I was not monitoring AFR's etc. Are you? It may be that now you have a lot less restriction that low down you may be quite weak. Might be worth looking at that.:confused: I know that once I had done a fair amount of work over the years and monitored AFR's and tuned that correctly all was good, setup.
Check the tdc lead, it goes right above the exhaust and you may have knocked it? Make sure its not fallen onto the exhaust seen that happen many times.
If tdc is fine, guessing it could be one of these - reference pipe to fpr might be split, faulty fpr, fuel filter blocked, fuel pump on its way out.
right ive moved the tdc wires about and it seems to be ok now ?
will i need a new one maybe wires are abit dodgy if i can remember from back in the day my i had to do it to one of my old cars ?
if it is playing up would it stop the car from starting as it did this ?
Sometimes they do stuff like this when the tdc is on its way out. Whack a new one on mate
are they easy to fit or they need setting
Just simple straight swap mate no setting required, take you ten mins:agree:
ok cool i shall get one cheers mate :)
