Help please ..
Speedo isn't working
Not sure if its the clock or something else
Any thoughts or tips appreciated thanks
I have the clock out is there any way to test it?
Or where does it get the signal from?
Help please ..
First check its still connected in your gearbox or burnt on your exchust follow the wire to the joining black clips pull apart and separate a little the three male connections as try get worn.. Ten clean the connections behind the clocks.. Of those three don't worked your ****ed :) worked for mine after two years of not workiń
Thanks mate will try that
Mine was the connector on the back of the speedo
http://i1259.photobucket.com/albums/...ps4bfc4737.jpg
Theres also a plastic strip there with 2 or3? metal strips on it., make sure thats not gunked or has crap on and put back in.
Also,
Disconnect this, clean and put back.
http://i1259.photobucket.com/albums/...ps32734cfd.jpg
I had to just adjust the speedo needle as it was 10mph out, prying it off with a fork and moving it 10mph forward, if you do, it's very delicate so be careful...
