Hi all, just picked up my first r5 turbo, its a d reg ph1, heres a quick spec list...
Ported polished big valve head triple angle valve new valve seats shortened valve guides matched manifolds oil gallery mod,1.9mm head gasket set.uprated bolts.
piper 285 cam
Group a carb
Low compression pistons
New liners
All new bearings mains,big ends, thrust washers. New oil pump,balanced crank flywheel, new gaskets. ,group n clutch,
T28 roller bearing turbo.
Braided oil feed turbo.big turbo elbo k Tec 2.5 down pipe side exit system
Pro alloy grill mounted front mount
Full set blue samco.
Alloy header tank
Alloy swirl pot
Alloy breather swirl pot
Alloy breather tank
Alloy carb top
Alloy bleed valve
In car boost k Tec
Big brakes 285mm
Spax 40mm kit
im having trouble with it idleing tho, coming up to junctions/rounabouts it seems to stall 80% of the time unless i keep a little throttle on,
the car has sat for a while and today had its first long run in a while, it drives fine and boosts perfect (well i think so) but its just the idleing that lets it down, can anyone point me in the rite direction to what it possibly might be?
sorry for the neewbie questons,
Thanks all
Ellz :)
