as per title. struggling!! any tips?
pretty much gaining access. getting there. charge cooler in the way didnt help. will stick at it
It's like all these things mate, you've got to remove a fair bit of stuff before you can get too it.
It's one of those where you have to let your hands be the eyes :scared: but it's only three bolts when you can get too it.
Just make sure you are careful when you re-connect the starter motor Power Cable as if you don't orientate the connector to the starter motor correctly, there is a risk that the cable will earth out on the Exhaust Downpipe.
I should know, I did it!! :cry:
Disconnect the battery before you start!!!! :scared:
got it done. never again with a bit of luck! you'll be glad to know the battery was disconnected and the car wasn't hot ;)
lol leaving the cooked for-arm for another day :agree: :laugh:
I know its easier from underneath the car.
also depends if its been off before and if all brackets, heat shields are there or not.
