Re: fuel pump not working.
I would say your problem is your earth to the fuel pump relay.
was thinking/hoping something like that, where do i find that earth then?:scratch:
Right Gary, wiring diagram shows the relay is earthed through pin 21 on the ecu.pin 21 should lead to no. 85 on relay. So if this is earthed correctly and 12v is present at 30 and 86, 87 should Provide 12v to 86 on second relay. Second relay is earthed between second relays 85 and 17 on ecu. If this is all correct it should fire injectors and fuel pump. I think this is correct, :eek: it's late I'm tired.:wasntme:
now im even more confused:crap::laugh: so if one relay is broken both wont work:scratch: Il have a read in the morning cheers matey:laugh:
Yes one relay triggers the other.
I can get a wiring diagram up tomorrow night as I probably not making sense.:laugh:
The wire coming from the relay that's supplying 12v to the fuel pump and injectors is grey and red, probably. :laugh:
its super Andy to the rescue :cooter:
thats the one i have taken to the the old gtt relay and bypassed it and connected it to the white wire that goes to the fuel pump. Must be a prob with the relays as i did the wiring so there wont be a problem there will there:scared::wasntme:
cheers for the help tho matey going to get some relays then pop down to the car and have a look:rolleyes:
if its not the relays then its probably an earth like i mentioned earlier, this is what i mean
haz, puts these things into better english. :laugh:
Haz
. with the ignition turned on one relay should click. the other when crankin. the fuel ecu should earth the second relay. you can manually earth the relay when all connected, if it clicks the either the wire to the ecu is broken or ecu is at fault, like a sensor down like tdc.
cheers for the help buddy. il most prob be going down to have a look in a few days so il let ya know how i get on;) So im looking at earths, relays, poss tdc sensor etc... ordered some relays just in case as i need one any way better to not need it and have it and all that:D
