Grigio moon ph1 r5 progress thread..
Thought it was about time I put a little progress thread of my r5, I have been into renaults since I started driving. Mostly clios though. But I now have a work van for week use so could now get myself a weekend toy :),
Here's my old clio..
http://i667.photobucket.com/albums/v...6_20-13-11.jpg
Swapped it for this r5..
http://i667.photobucket.com/albums/v...1/IMG_5792.jpg
I didn't like the look of the front end or wheels but this could easily be sorted. It had a good wod of recipts and a nice engine spec and with a quick test drive I new it was the one :)
Quick spec list...
ported polished big valve head triple angle valve new valve seats shortened valve guides matched manifolds oil gallery mod,1.9mm head gasket set.uprated bolts.
piper 285 cam
Group a carb
Low compression pistons
New liners
All new bearings mains,big ends, thrust washers. New oil pump,balanced crank flywheel, new gaskets. ,group n clutch,
T28 roller bearing turbo.
Braided oil feed turbo.big turbo elbo k Tec 2.5 down pipe side exit system
Pro alloy grill mounted front mount
Full set blue samco.
Alloy header tank
Alloy swirl pot
Alloy breather swirl pot
Alloy breather tank
Alloy carb top
Alloy bleed valve
In car boost k Tec
Big brakes 285mm
Spax 40mm kit
So first of was new wheels as I really didn't like the ones on it. So purchased some William wheels cheap :)
Also I didn't like the side exit so got a rear exit,
http://i667.photobucket.com/albums/v...1/IMG_2442.jpg
Next was to get rid of the gt tuning bumper and fit a standard Ph2. Picked this up for a good price but did need abit of work
http://i667.photobucket.com/albums/v...1/IMAG0315.jpg
Came back from the body shop looking like New,
Off with the old.. on with the new...
http://i667.photobucket.com/albums/v...1/IMAG0335.jpg
http://i667.photobucket.com/albums/v...1/IMAG0340.jpg
Next was to lower the front end as sits way to heigh for my liking. So apex -50 springs was orderd and fitted..
http://i667.photobucket.com/albums/v...1/IMAG0351.jpg
http://i667.photobucket.com/albums/v...1/IMAG0352.jpg
http://i667.photobucket.com/albums/v...1/IMAG0353.jpg
Getting the car rolling roaded tomorrow to check the fueling and see what horses she kicking out,
Got a few more bits on order so will update soon.
Cheers Ellz
Re: Grigio moon ph1 r5 progress thread..
Good work mate,change of wheels & bumper makes it look loads better!:):agree:
Looking much better with the standard bumper. love the ph1's
Thats looking pretty good now mate. Much better since when you picked it up
wow another phase 2 gt turbo, theres me thinking i was on my own! Paintwork looks mint mate!
Cheers for the coments. As it hasn't got standard interior it will be getting stripped with buckets and harnesses, is a weekend toy after all :)
Ellz
SALTY_BLADE
You mean Ph1?
Yh paint is good. Had. Respray in 02, was originally white
Ellz
gardner51
You mean Ph1?
Ellz
Nice car matey, ye get her stripped out:agree: get some more pics of the progress
gardner51
You mean Ph1?
Ellz
Yep should read the title lol, front bumper threw me!
Not much Ph1 left on the surface of it though, other than the rear arch mouldings.
A bit more faffing with the styling and it'll be a nice car anyhow :)
Cheers. Yup still a few things to do. But looking a lot better then it did when I got it,
Ellz
Well went to tcs performance last week for some power runs AMD check fueling, best it made was a 190hp,
Fueling was lean tho so its back their now getting this sorted, I would like over 200hp,
Will report back once I kno how she gets on,
Ellz
190 aint shy though mate, but lean running is a no no if you want to keep your head gasket in one piece ;)
get the carb sorted and she'll fly :smokin:
So its been over 3 weeks since I have updated this..... That's because I havnt had the car. It's been at a garage who is ment to be sorting out the fueling....
In the first week they found a blocked fuel filter, so put a new one on,
Following week they found something wrong with a needle in the carb. so changed that over also found a boost leak from where the choke had been removed..
This week their saying theirs a low down missfire and its.getting spark blow.. so new cap and leads on their way,
Now I'm getting really f'ed off with this company, I have read a lot on how easy it is to get them set up nearly rite. Drill out second stage ect,
I'm tempted to just go get the car back. Get myself a afr gauge and try myself or get someone of here to help me out n pay them...
Ellz
Update time...
Finually got the car back, its now producing 192 Hp at 24psi, only couple more hp but I have gained 10hp in mid range,
Have also fitted some front fogs, buckets and harnesses. Will upload some new pics later on,
Ellz
Here's a quick pic of front end with fogs fitted. Looks so much better
http://i667.photobucket.com/albums/v...815_141153.jpg
Ellz
Havnt updated this in a while!
On the 22/9/2012 took the 5 out for a spin after fitting a new front mount,
Plodding along down a main road at about 40 and boom. Looked in the rear mirror to see nothing but white smoke!
Revs died and I just rolled to a local laybye. Instantly thought head gasket but the temp was fine! Had to get recoverd back to my garage and start investigating what happend...
Ill let pics do the talking.
http://i667.photobucket.com/albums/v...pse1995e7a.jpg
http://i667.photobucket.com/albums/v...ps7f024e8a.jpg
http://i667.photobucket.com/albums/v...ps225e1af2.jpg
http://i667.photobucket.com/albums/v...ps90b3819e.jpg
http://i667.photobucket.com/albums/v...psa67726da.jpg
Ouch :(
So have been collecting parts since this happend and am almost their,
Atm it's still in peices, piston 1 is out ready for the replacement to go in.
http://i667.photobucket.com/albums/v...psf2d5a732.jpg
http://i667.photobucket.com/albums/v...psbe121619.jpg
http://i667.photobucket.com/albums/v...ps99926b50.jpg
Just waiting for my turbo to come back and downpipe to be made then its systems go for the rebuild,
Elliott
Wow that's quite interesting head work you've had done would that be a three angle valve.
That's not good mate I dropped a valve two years ago as did Dan last year. It'll be worth taking the exhaust housing off the turbo to check you've not damaged the turbine wheel.
Turbo has been sent of to get a smaller rear housing and looking over.
Ellz
gardner51
Ellz
That's good as I've seen some quite chewed up rear wheels after valves being dropped and one person has only just spotted it a year after it happening. :agree: good luck getting it all back together. :)
Abit of a update for ellz-
The head that failed measured in at 73.2mm thick - so above the 73.0 limit for big boost people talk about. Im not totaly sure why it failed but ran sweet, was very quiete on idle, probably the quitest c1j iv heard. Was a shame as head has had alot of work, valve guides ground down flush, heavily ported, and was running different valves, ctm stamped on it so its had the work.
http://i15.photobucket.com/albums/a3...ps8929f9c8.jpg
http://i15.photobucket.com/albums/a3...psc370d443.jpg
http://i15.photobucket.com/albums/a3...headddd004.jpg
sourced a 2nd hand head which measured in at 73.4mm - standard thickness i beleive? Has also had some head work - not as much as previous head but some nice port polishing
http://i15.photobucket.com/albums/a3...ps59515ee7.jpg
http://i15.photobucket.com/albums/a3...psd684e80f.jpg
Head was stripped, chemically cleaned and all valves cleaned and re lapped in - then re fitted with piper valve springs and some valve stem oil seals off a 16v vauxhall as told these are tighter and should not lift
http://i15.photobucket.com/albums/a3...psfe75fdec.jpg
http://i15.photobucket.com/albums/a3...ps4fc41b42.jpg
Save the head I'm sure Sid is looking into machining metal gaskets :)
Nottswoody
haha look at the pics above mate - it dropped a valve and smashed it into the head - heads well beyond repair unless your very keen and talented
Cheers James,
The head is pritty gone I think mate. Valve got pushed up back into it and smashed it a little, plus wouldn't mind keeping it as a suveneir on the shelf lol,
Also been collecting a few bits ready for the rebuild.
http://i667.photobucket.com/albums/v...1487527ABC.jpg
http://i667.photobucket.com/albums/v...ps20e065fd.jpg
http://i667.photobucket.com/albums/v...ps8c90ebfb.jpg
Elliot
got cold towards the end of the day though! While I was there I checked Elliott's carb - it had been to a mini tunning place for carb setup. Biggest drill bit I had was 1.5mm and it fit in the main, so suspect a 1.5/1.6mm main in there. Cant remember what ac was 1.1/1.2mm - probably standard. And you guessed it 2nd stage untouched. I drilled 2nd stage to 1.2mm and will be fitting a standard main and then checking it all on his new afr gauge and going from there
Making good progress, wont be long now. All the cold nights out tinkering will be well worth it :D
Yup can't wait to get back boosting! It's been far to long!
And cheers for the pistons again!
another step forward :)
got everything plumbed in and ready to start priming oil ect,
http://i667.photobucket.com/albums/v...ps0911b7f0.jpg
removed king lead and cranked over, but noticed fuel pissing out the side of the carb, so thought must be the diaphragm split, so orderd a new carb gasket kit,
so I removed the fuel pump relay and continued to crank over trying to get oil to come out of the turbo oil feed,
tried this for a while but no joy,
didn't want to take sump back off to pack with Vaseline, as I had just siliconed it up and its abit anal to get off,
so tried over filling the oil and crank over but still nothing,
so drained excess oil back out and orderd a second hand dizzy drive to mod to spin oil pump.
parts arrived day after ordering ( Thanks Mike)
went back down garage to sort everything out, modified the dizzy so I can spin it with a drill, I had a spare distributor aswell so I used this to spin the drive...
http://i667.photobucket.com/albums/v...ps9cd80470.jpg
http://i667.photobucket.com/albums/v...psa7818fde.jpg
after 5 seconds I had oil coming through the turbo feed and also was getting good oil pressure, so put back the old dizzy drive and distributor.
next I took off the carb and set about replacing the diaphragm,
did this, put carb back on, re connected everything, cranked it over ready to start but again, fuel rushed out the side of the carb.
I then started getting annoyed, shut the garage door and went home,
after a few posts on facebook, I then realised what I had done.... fitted fuel line into acc pump outlet, haha!
so this morning went back to garage, moved fuel line to correct place, after a couple of attempts of starting, She Fired up!!
couldn't stop smiling haha!
(Video)
http://i667.photobucket.com/albums/v...ps63df8223.jpg
just a couple of things to sort out now,
then mot, tax and hopefully good weather!
looking sweet mate :niceone:
Well done matey, I hope my oil comes out me turbo feed like yours has, I've had issues with my daily so not had chance to look at me 5:rolleyes:
Have you got a modified dizzy? If not ill send you mine and just post it back when your done? Makes oil priming so much easier!
Ellz
She sounds well :)
Looks like you got an OE grille? Get some pics up when you're all done :agree:
gardner51
Ellz
That's a kind offer :agree: I've packed mine with Vaseline so hopefully this should do the job, but if it doesn't I'll be pm you :)
Trevhib
She sounds well :)
shell sound better once the blow gets sorted between the downpipe and crossover pipe!
yep got a oe grill to go on,
just keep running into more problems!!
when I go to start it, the starter motor just clicks.. even with a jump from my van, if I then turn engine over by hand a 1/4 of a turn then try n start, it then trys to turn over a little but gives up, as if the starter hasn't got enough juice?
took starter motor off and tried it on the floor, it does come out and spin but is noisy,
so will be getting a new starter and new battery!
Has anyone else who is running a lightened flywheel have similar problems?
was speaking to mr smith (cant remember his username) he seems to think it could be because the flywheel has been shaven a little, bringing the flywheel closer to the starter, then not allowing the starter wheel to come all the way out?
Ellz
Got a brand new high output starter here if you need one buddy
how much? and where did you buy it from?
Great project thread :agree:
Great project buddy.
Just needs a standard front grill and job done :)
Cheers.
Have a standard ph2 grill to go on when she's road ready :)
Ellz I didn't know you knew Alex that works down at mark fish.
Yep.... Known him for a while mate. Havnt seen him ina while though! Need the motor back on the road and ill go see him.
You know him then?
Yes a very long time mate , next time ya speak to him just mention r5 Matty from harlow !. Small world!. You going to the curry nite?.
Will do!
Yes mate I think I will go to that. My mate James from Cambridge will be going to so will be with him,
Update
So all up and running but no brake pedal,
Found one of the pipes split from the master cylinder to the rear brake valve.
Replaced both pipes as thought might aswell?
http://i667.photobucket.com/albums/v...ps77623725.jpg
http://i667.photobucket.com/albums/v...ps8ae8a081.jpg
http://i667.photobucket.com/albums/v...ps6f02f11c.jpg
After this and bleeding the old fashion way pedal was still the same!
So decided to buy my self an eezibleed kit.
And as if buy magic I had a brake pedal again!
Car is now booked in for a mot next sat. Then she'll be getting taxed. Then the running in begins!
Elliott
yes lad well done - caliper do the job??
get her run in a few miles and we'l start setting it up
gttjames
Yes mate. Just needed a good bleed mate.
Yes will get it set up asap. But it's still got to go mate.
Just seen your project update. Looking good man! Need to hurry up though if you want a 5 boosting day!
