after a quick and easy fix please
right, raider of love has one niggle, when you accelerate, it hesitates before it goes.. if the choke is out, its ok, but without choke it seems to hesitate when you press the accelerator. ive changed the acc pump diaphragm as that was leaking, but still no change.
just wandering if anyone has had anything similar in the past, and if so is there a quick fix so i dont have to spend hours out in the cold :agree: :laugh:
Re: after a quick and easy fix please
Sounds like the ac pump arm needs resetting:). The old 5mm drill bit jobby
thank you james, not the quickest fix but i'm sure it'll do the job :)
is the carb standard?
also do what James mentioned :)
i've not had it apart to check jets, but as far as i'm aware its standard
car only runs up to 11psi, but it doesn't even need boost to missfire. just annoying as driving 'fast' isn't as fun as it should as you can pull smoothly out of corners without it jerking like muhammed ali
Sounds like it is the accel jet Mark, it will be blocked. It's that funky hooked thing that squirts fuel straight down the venturi. Checking it, and if duff removal and refitting, is very easy.
Gives very annoying hesitation everytime you put your foot on the accelerator if it's blocked :agree:
Get a new one if poss. Not sure how you'd unblock something so piddly thin.
Trevhib
yup, engine off, remove carb elbow, look into the top of the carb and watch what happens when you open the throttle, it should be a nice squirt through that jet down into the venturi, and not dribble around the edges. If it looks OK, do the 5mm drill bit jobbie :cool:
oh, and the linkage can seize, so you might need to free that off, pretty obvious when you look at it.
this is exactly what mines does, someone said about sorting it in someone elses thread but i've still not got round to it..:crap:
i'll have a pop at mine later too:cool:
Andrew Cooke
:agree: Thanks Andy.
thanks guys, i still need to take a look, but at least i know what to look for when i finally get me arse in gear :laugh:
Could someone please explain the "5mm drill bit jobbie" set up, as my poor old 11 suffers with this hesitation problem! :cry:
James5
What's the 5mm drill jobby mean. What do you do.
with the carb removed, slide a 5mm drill bit inbetween the throttle plate and venturi wall and then adjust the acc pump arm.
raj
my problem is motivation, until the raider stops working i find it hard to do jobs on it, usually let them build up and up then have to spend a cold evening out on it :laugh:
