4 Attachment(s)
Re: gtt sus springs and pics
:scratch: All the 5's you've had & you need pictures of some lowered ones?!
What is this club coming to?! :rolleyes:
The following pictures show the progress of a lowering a 30mm drop. Unfortunately I don't know what make the springs are, i just bought them off flea-bay :crap:
How much black do you want :o
Didn't you know Tim is Gangsta'?
Tim - Is that a 'laguna style' grille?
NightRiderrrrrr! Wana swap shells tim :P
BriC
FPMSL I was waiting for you to pick up on that you c0ck!
No, its a Megane style grille :p
sphinX-B17GTT
:laugh:
That was my car about 5 years ago. Lord knows where it is now, I think it had been totalled the last time I heard.
:laugh: It was a genuine question - I thought it was, but I wasn't 100% sure. It is the same style as is on my campus. Pretty crap, but looks better than a campus grille.
Big Steve - Raider
yeha man, always had them already lowerd or slapped a set of coilovers on, this one just needs to go down another inch i think, wana do ala cheap tho
Adey aka Ewok
cut a coil and get the chav cut spring bounce as you drive down the rd ;)
ok not that cheap lol, needs to be able to go round a corner without fear of the spring falling out
Blick
or be a supper cheap chav and have four fat bastids in ya ride..... innit:pimp:
THE MASTER
or put a load of concrete slabs in your boot like i have seen
before!!
:dearme::sad2:
its the front thats a problem, the back is low enough:agree:
so what springs are on there at the moment adey?
Adam 005
wouldnt 50mm springs cause shocks to bottom out.? i have koni yellows on mine and would like to get the front to sit lower,but info on the koni website states that they advise 30mm at max.
also adam,what size wheels are they with the 50mm springs fitted?
raj
if you use o.e shocks then 50mm is to low you will lose damping as piston in shock have very little travel left saying that my springs were on o.e shocks for a couple of years. The wheels are 16" with a 37mm off set they fit fine with no body mods:agree:
could someone recommend a place to buy a set of 50mm springs from? the cheaper the better.
J$£5GTT
Not sure buddy, there blue and look about 30mm down any ideas? Ive seen some on ebay that are ment to be 55mm down. Waiting on a price to refurb the coilovers tho but its looking to be quite pricey.
Adey aka Ewok
did you try abp motorsport??
Adey aka Ewok
Have you tried looking on the Koni website. I got in touch with a company in Newbury called raceline suspension, got hold of them through the Koni website, and they wanted £120 a side to refurb and change my Koni yellows into coilovers? I didnt think that was too bad?
once upon a time i tryed some 50mm lowering springs on the front of my camparse but the springs were 300lb jobbeys and made to front end way to high . basicaly when i put it back on the floor the srings were so stiff/strong there was no drop, so i opteted for some slightly softer ones and got it to sit just right
http://i274.photobucket.com/albums/j...e/JEB24034.jpg
:cool::p
Apex do -50mm springs thats what i've got and it sits quite low.You can get them from eurocar parts about £50+vat i think.Hope this helps:)
THE MASTER
:cool::p
that's tyre smoke at the rear wheel isn't it Col? :cooter:
