After 2 tyres decent ones toyo proxes or something?
Any drove my car about 4 weeks and the passenger side outer part of the tyre is like bald? Take it i need my camber sorting? It any seems to that side drivers side aint too bad:confused:
There isn't any camber adjustment on the 5GTT.
Probably an under inflated tyre.
under inflated(inside outside wear as it runs on the sidewalls) over inflated wears the centre tread, toe in wears the outer edge usually of both tyres toe out wears the inners to be wearing the outer edge your camber would be noticeably leaning out at the top. its more likely to be play in a component causing that wheel to toe in whil driving.(new components arent always ok) Check for play if theres no play then get your tracking checked. You should get your tracking checked after any suspension work really but if theres play then theres no point doing it.
if you need one desperate got one continental 15.00
cheers carlos
Got a set in at the moment.
Got 2 now thanks guys.. Am i going to be having the tracking done when i fit these ones so ill see how it goes :agree:
Checked all parts seem fine to me all tight etc
