Oh and, what's yours is mine...and what's mine is mine :D
Bugger this has come around quick!
Well I had better try and make some time to take the car off the road and fit all my new mods. Only a few to do :O
New inlet manifold - bit of work on the tb also
Fit / time cams - new uprated springs and new oil seals
Cambelt change
Water pump / coolant flush
Weld up new air filter intake system
Baffle sump
Fit oil pressure / temp gauges
Make new turbo downpipe section - if fitting the garrett
Fit new rods - so head off
Bit of head work
Good service
Mapping
Track tyres back on
Review fuel sytem setup and change to braided fitments and adj FPR
Geo - needed
And last but not least my new rather big rear wing :D
Figers crossed should give me a 10sec run as the clutch is now sorted after last year slipping mess :D currently running 0-100 in 8.7 so hope to get that down to a very low 8 with a gear change less due to raised rev limit and extra 50bhp.
Is all else fails I am sure I will still make it but not sure if I would run in current setup as I know what it can do - cannot better 11.3 :(
Would be great to catch up with the gang also as I have not seen most of your mugs for a while :D
DG
Just ordered mine :)
Just ordered mine and Tor's too :D Bring on the pod!!!!!!!!!!!
my cars still not on road yet.
fingers crossed i get it sorted in time.
pretty sure it wont be ready to run tho :cry:
Ordered mine, just need to get the van ready now!
Mines on its way to me now, just got to fit new engine to campus and set it up for 25psi then i'm all ready. :D
No that ones still being done mate, i got an engine with cam fitted to throw into the car and have abit of a laugh with.
Played with the cam tming abit so will see how quick we can get the little campus up the strip, wonder if the campus box will hold together! :crap:
I may have a word with Mike and see if he could bring one! :laugh:
Its held out ok at the moment, only reason i never fitted gt box is didn't have one also wanted to keep the standard campus clocks. Gears are slightly shorter but could bring gearing up again by using my taller drag tyres on the day.
I am sure I can squeeze one in. :D
