B18FT Oil Feed and Drain.
Has anyone got any pics of the rear of a B18FT just trying to work out how I'm gona route the oil feed and drain on my conversion and I can't picture it in my head... I'm using a prima tubular manifold to mount the turbo in the same position as a GT.
I think the oil feed comes from the back of the block, can that be blocked off? can you take the feed from the front of the block like you can on the F4R?
Cheers Ashy.
Re: B18FT Oil Feed and Drain.
Oil feed comes from back next to cam belt. Don't know about blocking that off. There is an oil pressure switch on the front where you may be able to take the feed from. im Using the std b18ft turbo oil return outlet and some 16mm superflex type oil hose heat wrapped to protect from mani, its tight but it just snakes round starter and engine mount.
