STD downpipe is fine as it can be twisted but the bms I fitted along with a t25 fouled on the driveshaft.
the big jim might be at a slightly different angle but might fail, any ktec etc enlarged downpipe using the standard turbo elbow allowing it to swing will be fine:)
you can get a v band from ebay at £30 or so and then welded up sorting any issue out.. if you know someone that can your downpipe to spec your winning..
Just got mine, thanks to everyone who have made this group buy possible, and especially to clee for shipping the manifold over to me in Norway :)
Are there any manifolds still available? Been a bit preoccupied and forgot to sort one when the buy started!!!
Two left :agree:
has anyone had issues with these being very close to the starter motor and heat soak...?
any of these left...?
Sorry no, but Clee is looking to get another batch.....
Just thought id mention, with no heatshield and tubular fitted, i didnt have one starter problem after a 120mile trip to mallory, 30-40miles on track and 120 back. I would advise taking your starter off when fitting (to make fitting easier too) but also spraying wd40 inside, plenty of it. inside the motor and the solenoid. I did prior to doing this suffer with hot start sticking solenoid on my standard manifold.
Is the new shipment in?
Will there be any more of those available?
Just wondered if there were anymore of these available 2 ?
gutted to hear these things dont seem to fit with a bms downpipe :(.. fail.
do they fit with a big jim racing one?
what i had done to mine to fit without it hitting driveshaft!
ah right i see, so you weld the two v clamps with a slight angle, coolio, well ill attempt to fit mine first without this modification, then if needed ill fit a V band.
Hey guys, just wanted to tell you that I bought manifold on ebay from kiwi- something for 130 eur new, so iam off the list...
Martin
i would like this to come about again, pity i missed out :(
there you go: http://www.ebay.de/itm/Edelstahl-Fac...ht_3276wt_1139
Just put your best offer... mine was 130 :)
Iam from Slovenia so thats 130eur not british pounds and + 15 eur post cost for Slovenia.
can u still get theses manifolds
is there any manifolds available, or maybe anyone has to sell?
just thought, will renault 5 tubuar manifold fit renault 11 bolt on?
Mine improved without any doubt, reved much much more easily, It did change the sound too which i like but some may not, i wish i had some practical figures but unfortunately i dont. You wont be disapointed IMO but i also wouldnt say its worth spending £hundereds£ on.
Has anyone heat wrapped one of these manifolds ?. If so can you tell me how much was needed.
Thanks
