half decent headgasket set, were do you get them these days,? im in hockley essex, anyone got one, or know were to get one asap, cash waiting.. call 07914076504
find your local GSF mate and you want the 1.9mm blue rimmed one not the red 1.6 standard one..
Corteco Head Set Mellior They Are The Best One To Use
Yes Gsf Are The Cheapest Second Euro Car Parts
Carlos
I can sort out normal ones for you easily, but can also get the Corteco head gasket from one of our suppliers, wasn't cheap though as it was something like £10 carriage additional because they dont really deal with that supplier.
Keep OE and uprated on the shelf
:D
Fitting the thicker gasket will naturally lower the c/r too(*), which, on an already low ish c/r engine, isn't a good thing.
* Unless you've skimmed the head to compensate for that of course.
The question here is can you actually buy standard gaskets anymore? Id rather fit a mellior or payen than some of the cheap crap out there.
I got an ultraparts head gasket on its own sitting here in my works draw, also some valve stem seals, should really empty my work draws every now and then :crap:
thanks for the replys, ive sorted it now, went blue as the head had to be skimmed a fare bit as it was detted to pieces , not on my car thow :laugh:
