Re: Charge temps?
Someone simply ought to measure the outgoing water temp of a charge cooler and see if it's the same as the air temp exiting it.
If it is, then it's doing a good job, but if the air is over 90°C and the water 35°C then it's a poor heat exchanger and there are no ifs or buts about that.
If an inter cooler is then fitted and the exiting air is 40°C.... Need more be said?
Also measure the water temp exiting from the 'pre-rad' to see how far above ambient that is. But why spend so much on such a convoluted system when the cheaper tried and tested does the job, apparently, better.
Re: Charge temps?
I would of loved to get it all working nice but I got fed up. The AVT rad was over £200 and who knows if it would sort the issue.
As you said Ian £73 delivered cooler from the bay and all seems well now.
I think it would be a good to have a thread of peoples ACT results. So people in the future can see what would be best for there application.
