B18FT into an oldish Clio
Hiya, can anyone give me some info on the above conversion?
I've seen the 5GTT engine go into a Clio with not much fuss and the B18FT into a 5 with not much fuss........... soooooooooooooo presumably the B18FT should go into a clio with not much fuss????- How do the two ECU's work? Do you need both of these during the conversion or can i JUST use one of Scoff's converted ECUS's? http://www.efi-parts.co.uk/index.php?productID=167
- Do i need to take the 5's gearstick and rod selector or can i use one thats on the Clio already and match this up to the 5GTT gearbox?
- Using the 5's box can i keep the existing dashboard and clocks?
- Can i use the suspension from a 5 on a Clio? I was thinking of using the rear beam off a 5 onto the clio and use Yellow koni's from a 5! Is this worth it?
- Scoff, can you make an engine wiring loom for the ECU/'s to suit the Clio?
- Will a T25 from a 5 bolt on to the exhaust manifold?
- Can i use the 5's Rad and oil cooler (with the 5's take off plate)?
I think thats all the quesitons i have at the minute, but would like to hear of peoples experiences of doing this conversion or of using this engine?!
Cheers Chris
Re: B18FT into an oldish Clio
pop on to www.clio16valver.co.uk as this conversion has been covered many times on the site and a few are doing it at the moment
Cheers, had a quick butchers around the website but found it a little confusing. Has anyone on here had any experience with this conversion or engine/ECU's?
search a member called reevio on there. hes done it a few times:)
have a little look through here chris. assuming this is the oldish shape clio your talking about. :D
https://www.rtoc.org/boards/showthread.php?t=5907
Kempy
Thanks for that Kempy, really good read!
I was thinking of doing the conversion into a Mk1 clio, is this easier/the same as the link above?
Can i get away with just running the 2 Volvo ECU's (inc Scoffs tinkered one) and not having to run all 3? If i went standalone would i only need the 1?
Will the 5 box fit onto the Volvo engine and into the Clio?
Any help would be much appreciated!
not read the entire thread but yeah, just the 2 ecu's the other volvo one is for the abs. standalone would on need the one ecu.
the 5 box is the same casing as the volvo so will bolt up an fit directly into the clio.
Haz
Cheers Haz, with regards to the ECU's do you mean the 1 from the clio and 1 from Volvo? If so, which one from the Volvo?
Cheers Chris
Chris Hebden
Cheers Chris
No, he means the 2 volvo ECU's Chris. There are 2 in the volvo, one for fuel and one for ignition. It is the ignition (EZK module) that needs modification to remove the boost limit :)
