Megane f7r Vernier pully?
Hi guys, have bought a set of cams for my F7R engine, and would like Verniers to go with it to have it dialed in correctly, but the camshaft sensor on the engine uses the current pully to know which plug to fire? Im asuming this will give me some problems?
Does any of you guys have experience with this problem?
Re: Megane f7r Vernier pully?
are you running standalone ecu if so not a problem it just reads off the flywheel sensor,
if your using the standard ecu you will have problems fitting a vernier:crap:
Im running original ecu ;(
I thought so,
could i be so lucky perhapes that i could bolt a laser cut trigger pattern on the back of the alloy vernier that has the same shape as the original and cheat it like that?
Probably to much work tho.. Have a brand new set of angel works verniers.. :(
