https://www.rtoc.org/files/Technical%...iming-disc.jpg
Woah!! Can you make that a bit bigger please, Andy?... I can't make it out...
'tis rather large innit :laugh: Good job I've got a 22 incher :p and a A1 plotter but i think it'll hide all the engine :confused:
theyd b there a good hour b4 the page loaded lol :laugh:
So those are the lairiest std cams? No wonder these engines struggle. You could run a diesel on timing like that. If these engines do have poor heads then they will need duration duration and some more duration.... 228degs is never going to do it. I reckon as a start you would need some thing with about 30degs more on an LCA (Lobe Centreline Angle please, we're not American!) of about 110 with 0.040"ish LATDC. Then you might start seeing some power and still shouldn't be sacrificing midrange.
LCA is not the same as LSA... we're engineers ;)
how can you tell how much LATDC the cam he quoted has?
infact how can you tell how much duration the cam he quoted has?
which has more duration, a standard GTT cam, or a Piper 270?
which has more duration, a Kent RT200, or a Piper 285?
How can you tell?
You're gonna say ' by measurement ' aint ya :D
LCA is about 170 on one and 10 on the other ?Somewhere in those figures I'm sure there's a clue :confused:
Cam A
Attachment 668
Cam B
Attachment 670
Lee,,,,
if Rennie and Honda can get 1000BHP + out of a 1500cc.......sure we can do something for you Lee.....LOL..
now, the stroked crank isnt near enough to sort what you want......wrong configuration from what i have been told....
BUT, that doesnt stop you sorting a 2.9 V6 block....working the heads and making some in and out bits.....low comp pistons and your away... woo hooooo...
or......are you into a bit of bobandaconker tuning.......£50 =50BHP
It's ' 2bobanaconka Tuning ' I think you'll find :smokin:
It has to be paid for out of my little car bits and bobs innit .But I can draw stuff up and get it machined .Not forged pistons though ................or maybe I can ..
At some point I'm going to have to spend some money but I want to make sure it goes to the right place for the right bits .
Nothing is available off the shelf at all ,not even an uprated spring so it's research ,research, beg ,borrow and steal ( well ,so to speak )
you can easily check the cam lift of those 2 cams
http://www.lunaticams.com/Tech/Cams/CamSpecTerms.aspx
0.170"
I'm sure the 2.8 lump cams I had were a good 60 to 80 thou more :cry:
Base circle 1.190" over lobes 1.360 "
See what I'm up against :laugh:
I need a great pooling of minds and experience :agree:
No idea on the rocker ratio ? How would I calc that from bench measurements ?
Valves are 44 mm in and 37 exhaust
Inlet 34 ........Ex 30.................:eek:
I've got a few days off for pissing about in the garage so I'm going to set up a block,heads and **** for measuring
It's the sexiest van you'll ever see .For all it's faults :smokin:
PRV .....Should have been a V8 but the oil crisis meant they lopped two cylinders off .Hence it's pretty unique as a 90 degree V6 :sad2:
I just want to get the best I can from it ...I don't want to move away from the PRV as it would no longer be a GTA .
AS a non engineer then (;)) could you explain to me the difference between LSA and LCA?
Unless the figures quoted were at a specified checking height then as an educated guess I would say they had about 0.020" LATDC and also assuming (I know assume nothing, but you have to work with what you have...) that the figures given describe the designed valve motion events then 8+40+180=228.
I don't have the foggiest idea about the specifics of the cams you mention, but I know that a cam with the specs I mentioned will perform very well. :)
by the way, Honda NSX-90 deg V6, not really that unusual, just not common.
Do need to be careful with measuring rocker ratios. When the rocker is the follower, the observed ratio changes with the installed valve height.
LSA is how far apart (angle of seperation) the centre of the lobes are.
LCA is how far off centre/tdc the lobes are.
Sorry to disagree, but LCA is Lobe Centreline Angle ie the angle between the centreline of the lobes (more usefully taken as the crank angle between the center of max lift on the exh valve to the centre of max lift on the inlet valve) , nothing to do with distance from TDC. You can have a given LCA and time it anywhere you like in relation to the crank.
LSA is just an americanism for the same thing.
And yes Scoff, as usual you are absolutely right:( TNFG is a rule we should all live by. My point seems to be missed though. The valve timing specified for that volvo cam (unless it has massive and probably destructive valve acceleration - not likely) is never going to produce an particularly impressive power output.
Go on then... cam degrees not crank degrees
sure, I didn't look at the actual numbers :)
re the lsa business, lobe center is the real term, lca seems to have gotten lumped with the same definition somehow, I think I'd know what people ment whatever they called it ;)
what do you mean about the lift? (know what you're getting at with the lies bit!!!) the apparent centre might vary depending on your checking height, but surely the centre of max valve lift is the centre of max valve lift, a physical property of the cam:confused:
by lift I'm meaning checking height. So seat timing may give you 118deg LSA (:D), 20 thou 115deg, 1mm 110deg, peak lift 106deg, which one is going to give you the best feel of what the cam will do in an engine?
To my mind the angles between the absolute peaks isn't probably as important as the angles at which you see 1mm of valve lift. I've given up, and only worry about LATDC, then play with duration at 1mm valve lift. Maybe I'm right, maybe I'm wrong. Plotting out all those cams was very telling (btw, they will be back up on this site soon thanks to Scoff writing a sexy bit of software)
I'm liking that Hotrodding site ...It's a bit of a read so I'll have to do it in stages :confused:
http://www.popularhotrodding.com/tec.../photo_05.html
Like I guess you've discovered, cams are a bit of a black art. For lower levels of tune, its all fairly basic but when you start going for it, everything interacts and nothing is simple. I tend to go for peak lift LSA(:laugh:) and LATDC, 40 or 50 thou checking heights miss out the lifting ramps, which is good for getting an idea of a profiles "area under curve" but how quick the valve gets off the seat can play a big part in how it behaves (along with everything else.....).
Talking to the cam grinder (even though it's all lies!) should let you know what a profile is intended for.
God I wish it was simple:crap:
