is the final coat on a pearl 5 a lacquer or a clear coat? cheers any one whom can help
Mara, I thought they were the same also!
I was just doing a bit of research on re lacquering the roof on the 5,and just read on a spray painting forum that there are "two very different beasts"(on a yank forum), god there nobs
its had me searching google for the past 30 mins,thinking I may have bought 2 litres of the wrong stuff,so i give up and posted on here :scratch:
i had a cold once,so looked online, and the forum said i have a month to live :cooter:
i should know better by now
there are 3 phase for painting pearl white:
1-paint white
2-pearl transparency
3-clear
Or as I did hit it in beige high build, put the pearl white base on, clear, take it out the paint booth push it in the sun and go balls lmao
Can't understand it really as it wasn't like the peal you add when doing a tri stage paint job it had white mixed in. I.e solids in not transparrent
Looks great when the suns not directly on it but goes.......well what ever it wants to really lol so the important lesson here kids was put white base on after primer.
99% of the pearls I have painted have been a straight up pearl base coat, with the only exception being house of kolor custom stuff, you may need to use a ground coat under some pearls but that's about it. Need any advice painting wise just give us a shout.
Thats what I mean I've done loads of Metallic jobs but never a pearl one, so I did my campus peal white but never did a ground coat of white so the beige primer shows through in certain lights not from a didn't put enough have coat on but from a traslusiant point of view. Looks cool though a " one off" lol
Al,
I would be inclined to go white basecoat, pearl and then clear coat.
See if you can get hold of
elmof1 https://www.rtoc.org/boards/showthread.php?t=20156
check his thread out or
Kiwicolour
https://www.rtoc.org/boards/showthread.php?t=21204
both have painted phase 1 pearls.
:cool:
the paint of de the gtt ph1 an ph2,168 and 317 this a same paint.
it to be very difficult to have the same colour enters the different one manufacturing painting.
here the result with autocolor/PPG
http://img26.imageshack.us/img26/7264/img2029p.jpg
