Re: a few b18ft questions
oooh good thread dude. :coffee: Scoff sells the ecu you need for £39.99
hi
- for 12 psi you don't have te change nothing!
- above 12 psi you have 2 remove r206 in the box.
- i currently run 19 psi in a redistricted ecu, above this the engine runs way 2 rich (maf needs to be changed)
- check my topic for bleedvalve setup.
- DV size i don't know, but a VAG DV is better than org volvo
kind regards,
Sieger
sorry i couldnt really find anything in siegers thread:scratch:
can anyone advise me on what underbonnet bleed valve would be best?
do i need a 2way OR 3way bleed valve.?
also where abouts on the b18ft do i need to fit this?
thanks for that sieger:agree:
but im still failing to understand where it all goes:ashamed:
i dont suppose you could draw me up a quick diagram on where to plumb everything?
sieger
whats the control valve? is this usually located on the firewall just above the turbo?
i thought i would just have to plumb the bleed valve inbetween the inlet manifold and actuator :scratch: or is that only gtt specific?
infact sod it, i'll get the local garage to fit it for me.
so i take it that i only need a 2way bleed valve?
the controlvalve is infact a LPG valve (winter or summer modus) so you can direct the flow off the air
sieger
so do i actually need this bit? i thought the bleed valve is simply fitted inbetween the compressor side and actuator.?:confused:
I have subscribed to my first RTOC thread.
no if you only have the bleedvalve installed, you cant change the boost with the lpg solenoid you can swith between 2. The one you have set by adjusting the actuator rod and a second that goes via the bleedvalve.
