I changed drivers side drive shaft 2 weeks ago. Now when I'm driving there is a whistling noise that speeds up and slow down with my speed.
It started a week later. Can't check till Saturday hoping it can be ok to drive!
Sounds like it could be a wheel bearing issue..
Hmm strange it's just happened after changing drive shaft oh well will change that the weekend! Lol
might sound silly - have you checked your gearbox oil....?
gearbox oil :agree: also if you have a gaurd by the bottom ball joint or the dirt shield behind touching the disc.
the nut behind the wheel??
pull the inner gater back see if the joint still has grease in there :wasntme:
It was nut behind the wheel. Took wheel off and had excessive play. It had started to undo the nylon part broke put some nut lock glue and tightened it back up.
Cheers guys
