Is there any good fault code readers for Laguna 2? I have GT model so...
Price should be reasonable too, of course there are CLIP, but it is rather very expensive.
Also if you could read all codes and remove those too.
Yeah, i would like to get one too as i think i'll start servicing my laguna diesel after the warranty runs out.
what exactly do you want to look at?
i think those models mentioned are all EOBD compliant, but you will only be able to look at engine stuff that relates to emissions.
GSF sell 987AA4884 which is a citroen/pug/renault tool, but thats £250-ish its tells you a bit more detail than just an EOBD reader.
How about this: http://cgi.ebay.co.uk/ws/eBayISAPI.d...id=p2759.l1259 ?
I would like to see real time data, engine tests and also engine data mostly.
all eobd tool will show such data.
that link seems ok.
uses the elm chip...do a search for elm eodb tools....
I sel an OBD2 tool at work called a scanguage2.
I can sort you one out for £115 :agree:
can you not do the ol paper clip trick on them & count the flashes?
snap on do the ethos 555 which is £500 quid,:)
hmmm...I have laptop so if you have program suggestions that are able to do following:
- Engine real time data
- Reading and erasing fault codes (also SRS and ESP)
- Manufacture specific codes should be included (at least most codes)
gsf sell this unit:
http://www.auteltech.com/fr704.htm
for about £250
In eBay that is cheaper...so I think that I will go with that. :) Thanks
