what people use on there turbo f7p any link will be nice and do the f7p and f7r use the same head gasket ?
This is what I run on mine :) http://www.performanceenginecomponen....asp?id=250592
Wont say what mine is, but think I could replace about 10 head gaskets before I get even close to that price
I didn't pay that money for mine it came with a head I brought ;)
there are more gaskets available. cometic has mls gaskets too for less money.
however when you're not going too extreme a standard head gasket could be used. the most probable cause a gasket blows is inproper tuning.
My f7p turbo I just used a blue seal f7p mellior std headgasket from ktec cost me 30 inc postage it was decent quality. But then I was only running 14psi to be honest I would have still used the same gasket for more boost as its all down to state of tune
mls every time:)
the others will blow under repeated higher boost, even if fuel/tune is sound:D
all about long term reliability;)
yes, depends on the block, if its oe, then yes , if its been re bored , you will need to check /or get it checked, but most are under 83mm bore so should be fine, if the bore is bigger than 83mm, get the 2.0 16v item for the williams, which 84mm :)
here is the link
http://www.performanceenginecomponen....asp?id=250593
[quote=HAndy;321897]yes, depends on the block, if its oe, then yes , if its been re bored , you will need to check /or get it checked, but most are under 83mm bore so should be fine, if the bore is bigger than 83mm, get the 2.0 16v item for the williams, which 84mm :)
here is the link
http://www.performanceenginecomponents.com/products/product.asp?id=250593[/quote]
Tanks for the info your the man :smokin:
look on wilmink-performance.com, they sell cometics for around €120....
