is it possible to delete all the questions on this thread for folk asking for part numbers?,just clutters it up,if its not listed with all the numbers folk have took time to post up,thats if you have bothered to look through them all,just sayin..
anybody have the part numbers for the front suspension bushes? i need inner and outer anti roll bar bushes and 4 wishbone bushes.
cheers
77 00 779 923 - LHS
77 00 779 924 - RHS
Part numbers for side skirt rubber strips
oe renault
oil filter - 7700727482
fuel filter 7711130026
Those caps which cover up the metal brackets of the rear seats
77 00 763 002 - £1.02 each
Boost hose rubber strap - same as brake reserve tank
77 00 695 993 - £2.32
Anyone got the part number for the euro rear light?
Does anyone have the part number for the fixings which hold the rear arches on. They seem to be like a stud with a self tapping/screw thread one end and a normal thread and nut the other if you get what I mean.
Looking for part number of steel spare wheel phase1 :ashamed:
sandwhich plate to block O rubber seal
Part no is 7703061090
sanwhich plate to block seal 770 306 1090
side skirt clips 770 308 0051
side skirt rivets 770 307 2197
no. plate lamps 770 136 6035
osr wheel arch fuel tank bracket that rots away 770 307 8180
Do renault still stock oil pumps? :confused:
Have a read of Ian's article on oil pumps before you shell out any money. It gives you all the info you need to make sure you get a genuine pump for a turbo model rather than one for a n/a 5 - https://www.rtoc.org/boards/showthread.php?t=4730
Bigfoot is right, there were tales of people using non turbo oil pumps and messing up their engines.
Il pass on the £400 sooner go conversion than spend that much on one, cgb reurb ones anygood? There £160 il have a read up onit too
A few years ago there was a pricing discrepancy with oil pumps. Renault used to operate with multiple pricing systems and one system (local uk pricing) showed £400 but the French system had them at £150, my friendly stealer managed to get me a brand new one at the £150 price :cool: :D
Not sure if its the same situation now though, only one way to find out I guess..
BB Code
Does anyone have the part numbers for the plastic wheel arch inserts?:confused:
Here is a list of genuine coolant hose and air hoses I`ve manged to get from Renualt so far, please can someone list any numbers for coolant hoses that they`ve managed to get not on this list.
6001021209
6001006589
6001021212
6001007412
6001007413
6001008136
6001006590
6001008463
7701203219
Maybe of some help to someone ;)
Ladies and Gents, has anyone got the part number for front wheel bearings? I've got a track day on Friday and while doing an oil change and pulling off the old front brakes, I noticed that the Front LH wheel Bearing is completely shot!
I think it should be:
77 01 205 778
That is quite possible the reason, my system is picking up the all the part numbers apart from the first one and x-ref them over to fit the Renault 5 gt turbo.
Dose any 1 know the part number for a phase 1 suspension leg thank you
Hey Just wondering if anyone has the windscreen scuttle panel part number? (as mine is starting to rust) and is it even possible to get one now? i phoned Renault and it has obviously been discontinued, does anyone have one they would like to sell? or does anyone know any after market manufacturers that makes them?
Thanks
Lockset (doors x 2, hatch x 1 and fuel cap)
77 00 795 831.
(Please note that the keys supplied are the newer style with an ignition lock style key blade, not the diamond keys)
