evening all not much of an update at the mo but received these pics over the weekend so thought id share with you kept the pic back of the head for the mo ;) but will show at a later stage
pics of the inlet we wanna see ;)
Another update, started doing my fuel set up last night whilst waiting for the manifolds still to be finished only downer was i ran out of fuel hose :cry: all 4 metres of it but ordered some more today so should have that tomorrow and also some fuel clips to keep it nice and neat inside the car also made a hole to keep all the lines under the car to keep it neat and hidden
here is a picture not finished i will add more as soon as the other pipe arrives and its finished
cheers phil
Pleas tell me you haven't used rubber lined hose Phil?
She's looking good Phil mate. :agree:
Ok the day has finally arrived and I now have my engine back after a Long long long long time :eek: but I think the inlet manifold has come out really nice only bad thing is the company can't and won't make me an exhaust manifold now so after selling my last tubular one to help fund the new one I will now have to by one but I have found one which I will order tomorrow and hope it fits or will only need minor adjustments. I have had quite a lot more done to the engine this time round so hoping if all goes well I should have quite a quick 5 also finished my fuel system off and as soon as my laptop stops messing around I'll load up some pics, so now the race is on to see if I can get all the work done and get the car up to scoff if he can fit me in before the fete day as I will be rather pissed off seeing everyones 5's there and not mine
here are the pics
and more
some more
more pics
more of the manifold
last pics for now hope you like
Progress being made... Looks the nuts mate! I am sure you'll be more than happy once its all done and your clocking up the mileage ;)
Thats a nice fannymold shame build time took a little while. :(
Good luck getting it all together if there's anything I can help with just shout mate.
Phil, looking good shame taken so long for fabrication of parts does look good, out of interest what size injectors and what TB are you using?
As per Logg's over if you need a hand doing anything I am more than happy to help matey:agree:
Looks well mate :agree: Id be welding the trigger wheel to the bottom pulley, and then the pulley to the sleeve if not already done as they can slip.
TB is quite common and is found on most renaults from an early meagane/laguna but this actually came from an 03 plate scenic which is still the same from an ealy 90's megane plus i went for this as the throttle cable is the same fiiting as the 5 and goes straight on the 5 pedal it,s a 50mm TB and injectors are siemens 550's
cheers for all your coments guys :)
nice bit of work there phill!:)
not a handy thing to make ,are they?
i have one very similar going cheap....pity u did'nt talk to me first...i'll probably put it on my own car....when i get time...keep up the momentum:)
nice work phil,
what is ET value of those wheels you got? and what is the tyre size?
i'm probely gonna buy a 7,5J 15 set with Et33 and 195/45 tyres
Hi sieger they are 8j's by 15's with an ET of 25 and the tyre size is 185/45/15's 75v the only place I could find to supply this size tyre was nankang and the Tyres were shipped it from Germany total cost for 4 was £180.80 Inc vat and post I think it's helped with the 185's as there is more on the stretch for the rear arches
Hope this helps mate let me know if you need any help
Phil :)
okay tx will keep that in mind :):agree:
i suppose they wil fit, because i have 7,5 J and et 33, thats in total 2 cm smaller.
some more goodies have arrived today my new 10mm magnecor leads made to measure all set lengths then i had some vacuum pipe arrive and i got my new exhaust manifold today 38mm, inch and half pipe work so should allow the engine to breath better now rather than being strangled by the old inch pipe work k-tec one i used to have really please with the manifold as there is half the amount of welds compared to the ktec or raceland ones and bigger :)
work on the car starts as from tonight so hoping to have the engine back in by wednesday
cheers for looking
phil
Cool looking fannymold you got there.
Surrey meet at your house this month to get it up and running. lol
It's a shame it takes Jim so long to do things as he does knock out some decent work, did he make the exhaust manifold in the end Phil ?
Chop chop son
bit more progress made last night got some small jobs out the way ready for dropping the engine back in tonight or tomorrow big thanks to Dave..h for popping over and giving me a hand hope the tea was nice. Next on the list fit flywheel clutch and cover plate gear box and starter motor then if time drop the engine in a few pics from last night atleast the manifold fits :wasntme:
right cheers to scoff for sending me out my exhaust boss next day delivery got it welded in yesterday now both manifolds on clutch and and flywheel now on as well as the gear box engine mounts in so tonight ill chuck the turbo on and starter motor on then drop the engine in so if all goes well ill think another week of evenings on the car it should be ready to go up to scoffs to see what it can achieve just a few pics as well
cheers phil
couple pics of the car
a good nights work last night in the garage and a massive thanks to dave..h for coming round and lending a hand getting the engine in, its as is everything was made to measure :eek: as nothing is in the way of the bulkhead and all sits nice and snug hopefully another good few evenings next week and it should almost be done :D
and some more pictures
looks awesome mate! i wonder for how long the bay will be that clean though :D
Phil engine looks good unfortunatly I can't say the same for you and Dave though :laugh:
