Very nice! Are you using the dephaser then James?
Had the old car mapped @ 23psi
Attachment 32178
new boots 195/50/15 profile going to have to raise rear a tad as they catch
Attachment 32179
Awesome James! I've been on with my fuel system to hopefully get it mapped!
I've still not finished my surge tank setup, I have to make sure my car stays at over 1/2 tank and its fine.
Got few things to sort out before pod now
- Fuel tank breather's (Pump clicks constantly when filling now),
- campus filler neck fitment
- Surge tank setup,
- Front camber bolt fitment and setup,
I had to raise the car 10mm for clearance of the 50 profile tires and even then they catch, whilst i raised I fitted the new koni rear dampers
Main reason for going 50 was the lack of 45 choice
I run 5mm spacers on the front just to give me a little clearance on the coil overs as I run a 10" spring for full damping benefit. The rears don't scrub at all but I am still on 40 series tyres. I'm not bothered about ride height as long as it clears speed bumps and handled well.
Few pics, change of plan with surge tank bought another kit mounted it in boot, just easier, now have an 044 lift pump and and 044 supply pump hopefully this will get rid of the half tank fuel starvation issue I was suffering with previously.
Raised the car 10mm for clearance on the new 50mm profile tiles, whilst at it I fitted the new koni dampers I have had for years. Had the car tracking all re-done and fitted some camber bolts at front aswell. Car feels and drives so much better now.
Hopefully be ready for pod very soon, bonnet currently at bodyshop for repairs
Attachment 32225
Attachment 32224
Attachment 32223
Attachment 32222
Looks brilliant James! How's the noise of the 044 in the Car? What sized fuel lines did you use?
Looks Great James, can't wait to see you at Pod. :agree:
few changes finally sorted my coolant issues turned out both gauge sensor for gtt clocks not working and the ecu sensor aswell all done and all fine.
Carbon bonnet fitted,
New clutch fitted,
Broke the clutch support on first attempt to drive the car :-( now looking at making a support bracket that comes of the gearbox main bolts and other places, keeps bracket in std place but secured in a few places and braces to stop it pivoting o n the thin upper bit of the bracket
Attachment 32422
Attachment 32423
Attachment 32424
Small update as I destroyed my Jc5 130 box recently I have decided to clean and replace a few parts, recently purchased a clio Williams sub frame setup apparently triple skinned. Benefits are the rad has a nice slot to sit in now which it didn't have on the gtt frame. Had the frame and subframe brackets all cleaned and powder coated. Gloss red frame and gloss black brackets, Ill be taking a few more parts over to the powdercoaters in new year
the engine bay will be getting a spray job in the next month by GTTurbo spares
Attachment 32449
Attachment 32450
Attachment 32451
Attachment 32452
Attachment 32453
Attachment 32454
Awesome that James! Probably something I'm going to do in the future although I can't change my subframe as it's heavily modded for the ndo gearbox and radiator clearence. I might pull it off and seam weld it all to stop flexing. I guess that's why your going 16v subframe?
What gearbox are you replacing the j series with?
Looks amazing James 👍👍. You certainly will be happy once the bay has been painted too. Top work as always 😎👍
Couple of updates and still more ongoing, also got a quaiffe box sorted to fit also
Attachment 32526
Attachment 32527
Attachment 32528
Attachment 32529
Looking good mate
Very nice matey. Manifold looks stout
Well, looks like this is the end of this thread for me as I have now SOLD the GTT.
I will still come to all events though just won't be in anything french.
Very sad time James. Hope you stick around. 😔
Best car club around won't be going anywhere
Attachment 32673
Attachment 32674
And very very nice!!!;)
Had the GTR almost three weeks now
Few upgrades,
Linney racing Discs and pads all round with billet bells,
SMT upper boost pipes with Tial BOV's ordered,
2 x rear Michelins ps4 tyres also now fitted.
I am now so skint, the family will be eating beans for the next month
Attachment 32675
Worth every penny I imagine!! 😄
2019 this seems like only yesterday. Suppose doesn’t help the car is back locally and not owned by myself.
I still have a hobby car but have moved on a little bit but do miss the gtt.
