Re: melted piston..but why?
you aught to measure the height of the cylinder head, it should be 73mm or more. Much less and there's your answer. After that you should check the operation of the AEI. the capsule may be leaky, or stuck and innefective.
Scoff,
Just checked the head thickness, its 73mm.
ta.
thats what happend to me,you may be ok with just replacing the piston
and liner for a used item and obviously sorting out what caused it in the first place,
jono have you got any pickys
Scoff
After the other week when I removed my head I saw traces of det and could not get my head around it, measured it after a good think and it measured 71.3mm:eek: No wonder it felt livley at low revs.
5 Attachment(s)
The pics were taken last night just after I removed the head.
Today I have removed the sump and popped all 4 pistons and liners out.
Obviously no.1 piston is mullered, though the liner looks in suprisingly good condition and its not split.
The other three pistons are all showing signs of detination too. They must have got pretty hot as the part of the piston that rubs up against the liner say the 6 clock position looks like its been freshly emery papered, if that makes sense! I will get a pic up tomorrow.
i would be interested to see all 4 pistons ;)
5 Attachment(s)
I just noticed that one of the other liners is cracked too. This probably explains the slight water loss I was getting. The level would drop from max to min over a period of 2-3 weeks. I just presumed I had a tiny leak somewhere.
Also I have a spare 209, but the module nipple is snapped off. Is there any way of replacing the module?
dunno if this could be right by saying it could have been running lean? just a thought?
