old member- looking for help in glasgow..
Hi folks. I used to frequent this forum many moons ago when my phase 2 gtt was on the road. Unfortunately the 5 has been neglected and has sat in a garage for the last 3 years. Ive been starting it occasionally just to keep it turning.
I was planning on getting it back on the road but unfortunately i am leaving the country to start a buisness. Im needing to move the 5 on but dont really want to split it as ive not got time to do that. I tried starting it the other day but it wasnt willing- changed plugs, leads- filled with fuel and has a new battery, but it wouldnt start..my mechanical knowledge has left the building!
Im wondering if there's any members on here that could offer some help..obviously i would be willing to pay anyone that could help me out?? ;)
Re: old member- looking for help in glasgow..
turbo1397
Welcome back to the club shame you are having to move the 5 on, but life gives us other opportunities which are more important good luck with the new venture.
Ref the 5, you getting fuel to carb (remove fuel pipe to carb and place in old cola bottle and crank and see if it comes out if does we have eliminated lack of fuel to carb, next thing is check spark, (put fuel pipe back on lol) remove the king lead and put a spare spark plug in the king lead and rest it against a metal part of the engine and crank and see if fires if so you have spark to dizzy then do the same for each ht lead. Saying all this is the engine cranking on the starter motor?
Also any pic's of the 5, colour, condition and value in it's present condition?
Could be tempted but only concern for me is distance
yeh its turning no bother.. it sounds like its not getting a spark- this was my first port of call. plugs i took out were smelling of fuel so the pumps working..
TDC sensor/ wiring, or AEI unit, replace the relay beside the AEI unit
Pm'd you also ref buying the car
No bother.. replied. :)
Check drivers side of the carb and make sure accelerator pump has not seized, you should see the flap move towards you of standing at drivers front wheel and opening throttle manually with your hand. This was stuck on mine and now it fires up. ;)
Checked the fuel flap at car and it's OK. Going to check if it's getting a spark and then fuel. Which pipe is the feed pipe going into the carb?
IIRC, it's on the drivers side of the carb and goes into the side of the carb top, above the float chamber.
Thanks for the help guys.. got it going. 😊.. sitting ticking over perfectly!
What was the problem in the end? :agree:
Not sure exactly which one was the problem. New plugs, ht leads and some new fuel.. and it fired.. 😊
@james5.. sent you through an email James.
Great to hear, nothing worse when they turn over and dont start, known it all too well recently! ;)
