Re: Genuine Minilite fitment
Thats a shame the wheels werent 60.1mm centre when made, spigots will be thin however at least if theres something in the gap there should be no movement at all.
Probably need spigots made of a sturdy material so they dont fall to pieces in minutes :scratch:
I think Minilite (KN) are really struggling. 10wks and they end up wrongly machined.
Anyway, if the beer can idea doesn't work, they can be machined out and fit nylon spigot rings to 60.1mm. Cheers.
Finally, they don't fit. Foul the caliper.
R&R Alloys are useless and Minilite (KN) even worse.
If they don't do a refund, they'll fit the Golf.
You really want something more substantial than 0.5mm shim in there. Something that thin has no rigidity, so it would be difficult to get a decent fit on both mating faces, and not do its job to locate the wheel. I would want at least 2-3mm wall thickness for something that is load bearing or providing a location on a wheel, especially for racing.
Depending on what material the spigots are, you could either get the spigots hard chromed and reground to 61mm to suit the wheels, or bore the wheels out, and machine up some sleeves and press them in.
Got any pictures?
I'm having more issues with these things. Will update with pics if I get a reply from the suppliers. Basically, they just don't bloody fit.
