Re: C1J Cylinder Head Wanted
hi phillip
I got one somewhere saved in the garage standard and never been skimmed will dig it out over the weekend and get back to you Robbie.
turbo ted
hi phillip
Nice one Ted:)
The head on mine was alot worse. i know you prob just want to do it right, but if you dont find another then im sure yours would be fine tidied up a little.
Tony Walker
The actual mating faces are all ok and i probably could re-use it, the main issue is i don't trust having another valve guide put in, the one that has broken was only replaced a few years ago, so would rather have one were the guides haven't been touched and are o.e . I'm still trying to work out how the damage has actually happened...........
have you checked your turbo turns over nice and free, a piece was stuck in my turbo i could turn it a little then it jammed, had to take exhaust housing off and clean it out.
Turbo appears to be spinning freely, the engine was literally shut off almost immediately after the failure, i see what your saying tho and maybe it's worth taking the housing off and giving it a check over.:agree:
I'm hoping not that much swarf has made it's way into the oil also. Turbo was pre-filtered but by one of those hose solutions filters that will only catch any large lumps of metal, I'm going to strain the oil that comes out also and see what i can find.
If robbie dnt have one ask Pete backyard he's local
shouldnt be crap in the oil apart from through the rebuild process. Atleast make sure theres nothing in the exhaust manifold. better safe than sorry, last thing you want is something flying through the spinny bit.
gtmatt
Will do Matt, cheers:)
Iv'e got quite a few lying about, pop down Phil & you can have one foc, you can even choose the best one (I'm moving units & am de cluttering)
Nice one Alistair that's a great offer, do you know much about where the heads you have came from, i.e off running cars ect?
Cant remember sorry Phil, I think they may have been from a few I broke many years ago but not sure, they have been in my barn loft for a long time. Ill take some pics & measurements tomorrow so you've an idea before you make the trip over.
