due to a previous thread i posted a couple of weeks ago about my split tubular manifold. ive welded it up at work and just want to know what the difference is with turbo spool up on them both and is there actually any proof of it.
I honestly noticed nothing but change of note from the exhaust from the raceland one
would you say the turbo spools up quicker i thought this was why people invested in these.
Nope didnt spool any earlier for me mate. And as you know mine is a very highly tuned engine.
From what iv been told before any get gains when running high boost really, just stick to standard one for the sound :smokin:
Best is o.e port-matched to the head.
a take it no one likes the tubular manifolds then.
Not the cheap raceland ones no. They don't fit and the welds crack, but what did people expect for under £200.
I like them if there proper ones mine looks good sounds great and does definatly make the engine breath better but it's bigger pipe work than the k-Tec/raceland ones
I like my DIY one but haven't had issues (yet). Someone should dyno engine before and after since this issue has been discussed many times before.
TNT Ross has one on and done a few year on it with no additional bracing etc, no cracks, great power delivery. It did need a bit of work to get it on. I have fitted 1 and braced it at 2 points - 1 oe onto the downpipe and an additional one off the gearbox to the back of the turbo - fingers crossed it doesn't fall to pieces. if it does, I'll be the 1st to let you know.
if the runners are as close to equal as possible, and no sharp bends to slow down /reversion of the flow of exhaust gasses, then the pulses hitting the turbine wheel should improve spool up mid range,and top end power on pretty much all boost levels, better than the o.e item;), off course to really see good gains, a free flowing exhaust, a ported/flowed head and cams that allow the engine to breath are needed.
i had one these raceland manifolds on my c1j 4 years ago it worked for me spooled up better quicker times at pod and no problems with the welds or cracking the manifold is on a none members car that i see regularly and its fine, maybe the earlier ones where built better:confused:
