Track Spec Clio 172, Essex
Phase 1 Clio 172
X 64 CDT
Tax: 31st December 2011
MOT: December 2011
Engine mileage: 108K
This Clio has been quite literally built up from a bare shell. In the space of four months from March this year almost every part fitted to the shell has been new from Renault, new aftermarket uprated parts, or sourced 2nd hand off the internet in very good useable condition. I have invoices for every new part right down to the nuts and bolts including parts that came from the donor 172 dating back 2-3 years.
Previous to buying the white Clio shell I owned a modified Odyssey Blue Clio 172, this was to be the donor vehicle for all the mechanical parts such as the engine, gearbox, complete front brake set up with hubs, braided brake hoses, complete rear beam with discs and calipers, bucket seats. As I owned this Clio since July 2008 I had the benefit of knowing that every single mechanical part was more than ok to use on the project instead of sourcing and buying a 2nd hand engine and other parts with potentially no service history.
This Clio has wanted for nothing throughout the build, it’s been built up to the best specification my money would allow me to do and to what you see in the pics. Its road legal and pretty much track and road ready.
Asking price is £4000 OVNO and open to part ex, I believe 1 of the criteria is having to post up a price. I don’t know if this is unreasonable but seems fair considering the amount of money spent on parts and spec.
I’m based in Thundersley in Essex.
Interior
Red Clio Cup LHD 6 Point Rollcage
Black Cobra Monaco S bucket seats on fabricated subframes,
Red Sabelt 4 point harnesses
Black OMP steering wheel
Mk2 Phs2 dashtop
Mk2 Phs1 dashclocks
Clio Cup copy door handle spacers
Manual window mechanisms
Interior loom trimmed back to the bare essentials
NO Airbag loom, Stereo loom, Central locking loom, Heater loom, Heater matrix, Pollen filter
Exterior
Aerocatch quick release bonnet catches
Mk2 Phs2 rear lights
Foglight ducts
Windscreen sunstrip
Suspension
FK Konigsports coilovers, adjustable damping, adjustable ride height F&R, neg camber
K Tec Racing solid top mounts
Geometry
1 degree rear negative camber shims
2.5 degrees front negative camber
3mm toe out
Wheels
16” Anthracite OZ Superleggeras
25mm hubcentric spacers up front, 5mm spacers on rear
Yokohama S Drive 195-45-16 tyres
Locking wheel nuts
Polybush
Powerflex wishbone bushes
Inner an outer ARB bushes
Dogbone mount bushes
Brakes
Goodridge front and rear braided hoses
New Renault hand brake cables
Front
Brembro ‘Max’ discs
Ferodo DS2500 pads
Rear
Renault discs, bearings and pads with new spare set rear pads
Engine
172bhp, 141ft/lbs
Phase 1 engine and gearbox
Renault cambelt kit fitted at 106K, only done 1k
New Renault gearbox speedo sensor
Valeo clutch fitted @ 90K
Clio Cup alternator setup with new alternator belt
Injector fuel rail guard removed
Exhaust
Decat pipe
K Tec Racing Stealth mild steel exhaust system
Genuine Renault manifold to decat pipe kit
Induction
90 degree silicon hose, 70mm diameter
Renault 21 Turbo airbox with 100mm diameter feed
100mm flexible duct to front grill
Sundries
Renault Type D coolant
Renault ELF 5W 40 oil
Renault transmission fluid
Renault DOT4 brake fluid
http://farm7.static.flickr.com/6110/...fb8a115c_z.jpg
Clioshoot 013 by Ricard o1, on Flickr
http://farm7.static.flickr.com/6059/...718d5b5c_z.jpg
Clioshoot 015 by Ricard o1, on Flickr
http://farm7.static.flickr.com/6006/...35e9ca0a_z.jpg
WP_000314 by Ricard o1, on Flickr
http://farm7.static.flickr.com/6052/...9320d380_z.jpg
Touristenfahrten - 01-10-2011 by Ricard o1, on Flickr
Re: Track Spec Clio 172, Essex
:cry:
I'd snap this up if I had the money.
No offers Rich, its worth more than what you are asking for it.
Hero car. You're bonkers selling it mate :( You got a new project lined up?
????? rich you just finished it:scratch:
Mmmnnnnnnnnn if I had that much spare would keep it for a daily blast / track days in the wet / ring car - later 2 due to the track beast not allowed at ring and cant imagine its anything other than dangerous in the wet lol (it was with 100bhp less :scared:)
Looks a nice example and knowing yourself it wil have been done right
Give it me cheap and will do a vag tfsi conversion :cooter:
Still regret selling the vag 5 in some ways :cry:
DG
Mr G you need to be buying a Clio shell and dropping it off with me for project no.2. I want to do a 6 speed Haldex 4WD Clio turbo, it should all fit just fine, I just don't want to pay for any of it :D
Scoff
Been catching up with Mr R at lunch and you have no idea HOW close you are ref that!!
I have the S3 tfsi lump in the garage - ECU work done (375bhp give or take a few) with an uprated direct fuel inj pump job done other than the bits I have to make anyway. Currently doing this conversion for a VX220 and using the 6 speed box 2WD box and should go well :agree:
I am getting lazy (and skint lol) and need to get Sarah drunk and suggest another project car in our life.....because I of course need 3 cars to myself :scared: and have loads of time free - maybe giving the car to you is a better option
Cant see the turbo conversion for the clio lump less than the vag stuff costs me though?
Tried ALL my best wide boy poor man speech to Ricardo (taught by the master of tight....Mart) but alas he will not let me have it for £2k :wasntme:
Been a tough year and not even managed to get the track beastie out but as of Feb things change and hope to be back with in my very speical warped.......well you all know me :laugh:
DG
Nah, WV engine in Renault has been done to death. If you're going to use a Clio it needs to have a Clio engine if it's going to keep some identity.
Picture this: Phase 2 172, GT3071, 400hp, super 1600 arches, S3 running gear with 02M 6 speed transmission. Get the bits ordered ;)
Scoff
PM sent ;)
I know how long ago did I start something in a 5 :eek: you were about 21 years old lol
OK super 1600 arches, S3 running gear...........tissue:wasntme:
I have a box and haldex knocking around........:coffee:
Good to catch up with you DG :cool:
love this car :D
tempted to see if i can sell my clio and 5 before its sold
Thoughts of a part ex/deal with a nice GT Turbo :D :ashamed:
A very hard decision but it has sold :(
Clio 172 Cup..... Also sold
Ahh mate you Chang like The weather you bought a nice 5 again ?? Hope it's a keeper :)
gtmatt
As much as i love the 5s i'd struggle to use it as a daily :ashamed:
Saying that i could have bought that tungy J plate and ragged it about for a while :wasntme:
Anyway... On the lookout for something else
