No Wash Wipe on Windscreen?
As title suggests, my wash wipe is not working all of a sudden?? :cry:
If I give the lever a push nothing happens, the wipers do not sweep for the wash wipe function and the pump for the screenwash does not run either??
If I pull the lever down for the wipers in normal use they are ok but for some reason the screenwash function is kaput? :scratch:
My first thought is to suggest a knackered switch but I thought I'd just see if anyone else had seen this & knew the answer?
:sos:
Re: No Wash Wipe on Windscreen?
Are the washer pumps on a different fuse?
Mine was dead and Ianm fixed it for us, I'm pritty sure he changed a motor a little black thing in the bulk head by the wash tank and took off the block connector and used two plug in pins works a treat now.
He may shed some more light.
Mat
i had that a while ago...just gave the washer motor a little tap with a spanner an she worked,cleaned up connection etc,had a look inside an old one very interesting....:D
